Chauvet Colorstrip
Shannon D
Chauvet Colorstrip
After a week of playing with my 3 Chauvet Colorstrips, this is the fixture file I came up with. 90 Macros to play with. Actually that is what it took to make the Macro window look organized and not so cluttered. The Macro buttons that are white and not labelled can be used as "Black Out" buttons. There is one white button that is considered to be the "white" light. The RGB button is for color mixing in the Colors window. Enjoy!
Colorstrip SD1.pff- (230.15 KiB) Downloaded 293 times
matt
- Admin
- FreeStyler Version: NULL
Re: Chauvet Colorstrip
Thanks Shannon,
I have 3 color strips and you saved me so much programming time!
Rock ON!!!
Rock ON!!!
Matt Hankosky
flickr.com/photos/mattxhank
Shannon D
Your welcome Matt! I saw the post on FREESTYLER'S Facebook and now understand your post here. We are all here to help each other.
The biggest thanks from me is to RAPH! Thanks a bunch for all your hard work and dedication for making such an awesome program for us to use for free. You are the man!
whines
Thanks for the great fixture file!
I have a hard time remembering which chase is which, so I tried to make little icons showing what each one does. Attached is a copy of your fixture file with these icons swapped in...they may or may not make sense to anyone else.
Colorstrip-newicons.pff- Colorstrip .pff with visual icons for chases
- (215.68 KiB) Downloaded 97 times
mcneiltny
whines wrote:Thanks for the great fixture file!
DRMADD
Thanks, both of you. I know it took a great deal of time to do this. I do have a question though; when you click on the music buttons, isn't it supposed to react to sound?? A little editing in the fixture creator is a great workaround for this. Which is great use of the extra white buttons in the macros. I tried it and viola it works.
