i have a setup with:
- 3 pars (enabled for use in dmx400 & react to sound)
- 1 scanner
I made some cues which works nice with pars + scanner.
Then i made one with only the scanner.
When i switch from pars+scanner cues to the only-scanner-cue, the parlights are on.
Where did i make a mistake? How to solve this? I want only the scanner on.
Is it coz the pars are in dmx400 enabled? Or did i miss with the 'off, snap, fade'-settings?
thnx
cue doesn't work like it should
stompinne
malykazio
Re: cue doesn't work like it should
In first cue you turn on yours PAR. Now you have to turn it off. So in last scene of first cue or in first scene of second cue you have to OFF pars (set all values to zero for this fixture).
