In my simulation am controlling the intensity via a slider for a _varied > par 64_blue and what find in scan library is that half of the scale is the color of the can, and the other half is the intensity. I'd like to know how to modify the can so that the blue dims from full blue to basically very dim blue. I find that after I cross the threshold that the color blue goes away and the beam turns white......I want to be able to control the dimming down of the beam but remaining blue until the beam turns of at zero via dimming.
All the other colors do this too, when I do the sine fx, it screws up the visualizer because the color drops and goes to white under the library threshold set in scan library. I don't see a clear way to fix this....any have any input on how to fix this so it visualizes correctly?
thanks
Chris
Easy view par question/issue with parcan 64 (color)
kittmaster
- Commited FS Forum helper
- FreeStyler Version: 3.6.2
kittmaster
Re: Easy view par question/issue with parcan 64 (color)
Still looking for help with this issue......any one have any thoughts?
Nathanrs93
- FreeStyler Version: None
Hey kittmaster,
I did have a look into this for you but was not able to see a solution, however, I will have another go when I have 5 mins as I'm busy with work at the moment. But if you do up with the answer then be sure to let me know
Regards,
Nathan
Regards,
Nathan
