Here is all fixture files uploaded to the forum “User created downloads” collected in one zip file.
This is not an approval of fixture files that has been uploaded to the forum.
The fixture files in this library has been opened with the latest version of Fixture Creator and saved again.
This is to remove errors that earlier version did not check for.
Additional spelling of manufacturer name, value like 256 and eventually channel description has been checked.
All fixture are then save with a unique name including the manufacturer name.
http://www.freestylersupport.com/fixtur ... _04_01.zip
How to use the fixture.
Unpack the zip file and find the wanted fixture.
The double click on the file or open fixture Creator and import the fixture.
http://www.freestylersupport.com/fixtures/Icons.zip
Note.There are some fixtures in the “Icon” zip fil that only contains additional icons for Freestyler.
These fixtures don’t have a functionality but installed once they will give a bulk of icons to build new fixtures with.
User Created Fixtures Download
- FreeStyler Version: Beta
- FreeStyler Version: 3.4.4
Re: User Created Fixtures Download
This looks great and look forward to working with it soon.
Thanks for the hard work.
Jimmy
Jimmy
So here are the the fixtures from 01/03 - 2012 to 01/06 - 2012 which are now available.
http://www.freestylersupport.com/fixtur ... _06_01.zip
