Could i do this? how? Topic is solved
hypnotic_monkey
Post by hypnotic_monkey »
Could i set the BCD2000 up to do the following?
Blue = submaster control
red = override button control
pink = open/close window
green = general
Im sure the buttons can work well - but would the go/back for scrolling through the submaster sequenced.
And could i get the faders to control cue speed - and to change from cue 1-5 to 6-10 when i go through the sub pages?
How would i go about programming it to do this?
Thanks :fs:
Re: Could i do this? how?
Post by LJ_krede.dk »
yes, it is doable but there is a but!!!
1) you need the MIDIOX and midi yoke programs on you computer
2) You need to configure MIDIOX and your BCF
3) it take many hours to get nit work
I'm on work right now, but i have posted in another topic about how configure BCF and MIDIOX to do some stuff, similar to what you ask for.. Look at my posts and take a look
If you need more help, I will be happy to assist you
hypnotic_monkey
Found this:
http://www.freestylersupport.com/fsforu ... =16&t=2189
all i have to do is upload to BCF and change the config in freestyler :)
some comments to your picture...
you only have one tap sync button in Freestyler
you can't use the encoders to back and go unless you use a program like MIDIOX. I got it working but don't use it because it was lacking and not very reliable.
you can use MIDIOX for this using MIDI data mapping and Program change mapping
Return to “BCF2000”
