Work in progress - Onge
This tutorial is the first part in a series I am proposing to do on the Fixture Creator in FreeStyler. I intend to do a tutorial for each type of profile available when you first start the Fixture Creator. They will be “Parcan, dimmer,…”, “Fogger-Hazer”, Scan/Movinghd.“ and “Other”. This tutorial is for a Moving Head.
To get the manual and other information on this lighting fixture the please visit
Showtec Explorer 250 Pro MKII Info
TODO: The Macro tab. I will add this as soon as I can, I just wanted to get this main part done and onto the FreeStyler Support Forum as soon as possible. Resize the .gif image of the fixture so it fits better into the Fixture Creator.
Let us get started
