fixture_creator:framing_configuration
Fixture Creator - Framing configuration
Framing is basically a way to shape the beam.
It is done by moving 4 blade in front of the beam where each blade is controlled by 2 DMX channels.
Framing is enabled by check on the Enable Framing box.
fixture_creator/framing_configuration.1309463333.txt.gz · Last modified: 2013/03/11 02:59 (external edit)
