Hi mates, I don't know if this is a 3rd party software and you don't develope it but I hope you can help me clearing some dubts.
Unfrtunately the app can't be tested before purchase so I would like to be sure to receive what I need after payment:
- On the Lite version of the program I can turn on Overridebuttons but can't choose cuelist, with the paid version will I? This is the biggest limitation of lite verions, there will be any other ones..? Or should I consider this app enough good for have a remote-WiFi touch screen controller with an android tablet? What is yoour opinion?
- When I buy the program will it work only for that device? I've a quite old tablet, if in future I would change it, should I buy a new license?
Thank you for your kind answers
Questions about Freestyler DMX remote for Android Topic is solved
- djSupport
Re: Questions about Freestyler DMX remote for Android
Hi, Matt (Exever) is a long term friend of the FS Forum and develops the software on Android I'll alert him to your post!
- Twitter: www.120db.uk
Cue lists are supported on the paid version,
Apps on the google play store can be installed on as many compatible devices as you would like assuming they are all Android signed in with the same Google Play account.
I have typed a quick comparison between the two versions below.
FREE Features:
Sequence Playback: 10 Cue Toggle Buttons, and tap sync (long press to release).
10 overrides loaded from page one.
MasterFader / Locate / Fog Machine Control.
Auto-connect on both WIFI and Hotspot.
Fetch Fixture Patch List.
Premium Features:
Fixture Control - Pan/Tilt, Colour, Attributes, And Individual fixture selection.
Submasters - Full sub-master support (20) with Go, Back, RUN and Stop
Six pages of Sequence Playback: 20 Cue Toggle Buttons, with individual speed control and master speed controls.
Six pages of 32 playlist buttons, l and tap sync (long press to release).
Six pages of 32 Override Buttons
DMX Faders (24 direct access to DMX) configure within FS MIDI2DMX
Supports dual ports for connection with VirtualDJ
FREE Features:
Premium Features:
Get the Freestyler Remote App
Freestyler 3rd Party Addons
www.120db.uk
www.120db.uk
Thank you a lot, this is a really fulfill answer!
- djSupport
Cheers xever
Hi, unfortunately I'm living in Russia now and Google play doesn't allow me to buy it, no way to change country even if I use VPN, italian number, etc. There is any way I can legally pay for use it? Of course I can pay in Euro from a italian credit card. Thank you!
I0ve formmated the tablet, then did what above, then I was able to buy it
