Hii
I have a problem.
The window of lamp settings not showing up on my laptops.
On PC works fine.
(same fixtures, same setting)
The "icon" of lamp setting is shows but did nothing when
i pressed it.
Anybody help with this ?
Thanks.
Lamp Settings not showing up. Topic is solved
- FreeStyler Version: 4.1.1
- djSupport
Re: Lamp Settings not showing up.
Click reset window positions, let me know how you got on..
Hi.
So I solved the problem.
All you had to do was connect an external monitor and assign it a left screen.
The window appeared there, so I just moved it to the main screen.
BUT on another laptop, this helped me without connecting an external monitor
Thanks a lot.
Thanks a lot.
- djSupport
yes, so that button would of worked if you hadnt had an external monitor so its a good feature to know
