Problem Win 11 + Microsoft Surface pro 4 + enttec Open
ginof40
FreeStyler Version: 4.1.1
Post by ginof40 »
Hello :fs:
usually i use freestyler 4.1.1. on different computers without problems (1 laptop win 10, 1 deks win 11) with ENTTEC Open DMX.
I tried to install Freestyler and Enttec on a Microsoft Surface 4 pro (win 11 64bit) for use it in the live show by the touchscreen, but with the same configuration, fixture and scenes of the others computers, on the Surface, i have a big problem: it seems that the interface don't send correct information to the lights. The lights stops after few seconds in sequences.
So i tried to put only one light (30w Mini spot) in a new stage and i tried to move it manually... well the lights moves in a strange way: for example if i move the pan when i set the value >130 the tilt start to move, or the dimmer value set after 130 make move the lights (pan and tilt).
if i check the channel values (show outputs) the values are ok while the lights do the strange thing i told before.
That's not happen on the others Computers using the same interface..
Any ideas?
Thank you
Re: Problem Win 11 + Microsoft Surface pro 4 + enttec Open
Usb power saving? Change your power settings perhaps?
There used to be an issue I think with someone called USB selective suspend... As the surface pro is a tablet is probably power saving maybe?
ginof40
Post by ginof40 »
Hello!
first of all thank you for your help.
I tried do switch off all power saving options (i found many tutorials on line) but the problem is not solved :(
it's really a strange problem because the Freestyler and interface works but non in correct way :(
Are all the FreeStyler versions the same on your other devices? If this one is different perhaps it's a bug?
ginof40
Post by ginof40 »
Yes all the version are 4.1.1
I'm in dubt if is a Freestyler Problem or drivers interface problem.....
Uninstall the drivers and try again
ginof40
Post by ginof40 »
i did it and i installed different version... :-(
FreeStyler Version: 4.01
Post by Partyman »
Make sure all of your sequences are .chs filetype. pre 4.0 everything was .chb and i have found that those files need to be removed or edited and saved as .chs (then delete ALL .chb files to eliminate confusion)
ginof40
Post by ginof40 »
thnx for all your support. I tried all the solutions you suggested to me but nothing worked. So i returend to use my old laptop without any problems with same sequences! ;)
