Hi All!
When writing a sequence, if I set the speed value of the movements, save and go to the program, the moving heads make a very fast random movements. Just when i make a new sequences after saving!
I think this is a FS bug since the update. : \ Any idea? Thanks a lot!
FreeStyler v. 4.1.1 Movement speed changing issue Topic is solved
- FreeStyler Version: 4.1.1
- FreeStyler Version: 4.01
Re: FreeStyler v. 4.1.1 Movement speed changing issue
We need a little more info before declaring a bug. Please tell us the complete steps taken as to determine bug or user error. Please give all steps from opening sequence creator. Did you select the green option for pan tilt channels when programming? Does the sequence run correctly when you run it within sequence creator? What is your desired effect (go from point A to point B in 4 seconds)?
- djSupport
Also check the bug tracker to see if it's been reported already
So, if I want to make a sequence. I select the 4 moving heads and then click on "creat a sequence", all green or lightning in the top right corner. So far ok.
Then I select circle, for example, from the pre-programmed movements. If you do not change the speed of the movement, the problem will not occur. In factory setting, the travel speed is "1000". If I change this, either speed it up or slow it down from "0-10000", the "shape" will change after saving. It will be nonfigurative! : \ No more circles, squares, etc ... But just in the 4.1.1 version, and afther than i saved the complete sequence, and i run it.
Thanks for the reply!
- djSupport
pop it in the bug tracker and Raph the developerwil look into it
- djSupport
I've seen your report, hopefully he'll get back to you soon
