i'm new to Freestyler and alreaddy have a problem.
Ar start I set my lights (led par 56 American DJ) 1 tot 4 with the correct adres.
When I try the setup, it works fine.
The I safe the setup and close the program.
For now all goes well.
The problem appears whan I reopen Freestyler. None of the lights can be adressed, none of the preveous saved locations will do the job. The lights stay black.
However, when I make a new identical location, the lights wil work again, untill, you ca gues it, I save the setup close freestyler and start again.
Then the same problem again.
I tried reinstalling but no suc6.
Regards Frank
Problem using locations Topic is solved
- gardevil
- FreeStyler Version: 4.1
- gardevil
Re: Problem using locations
No one any idea??
- FreeStyler Version: 4.01
If you are using version 4.1 I would go back to 3.651 . i have had many issues with 4... that I have never experienced with other versions
- gardevil
Problem solved.
A clean installation of 4.1 has the issues i mensioned.
Completely removed,
then install version 2 (no problem)
Then installed version 3 (no problem)
The reinstalles 4.1 without removing erlier versions and bingo PROBLEM SOLVED.
tnx Partyman 4 tyhe solution.
Completely removed,
