Software
blumenman1310
FreeStyler Version: 3.5.5
Software
Post by blumenman1310 »
Brauche Hilfe,wie kann ich 4 Stairville LED 150 so programmieren das einer nach dem anderen angeht und dann wieder aus.Also so eine Art Lauflicht.Bin noch Anfänger auf dem Gebiet.Danke für Euere Hilfe
Nathanrs93
FreeStyler Version: None
Re: Software
Post by Nathanrs93 »
You'll need to set them on different addresses with freestyler and then match them addresses with each fixture . Then you'll need to create a step by step sequence to turn each one on and off.
MAAC
Just started using FS
Re: Software
Post by MAAC »
Use DMX400
SiGNe
FreeStyler Version: 4.14
Re: Software
Post by SiGNe »
MAAC wrote: January 29th, 2022, 1:53 amUse DMX400
Toghether with sound2light you don't have to do much for a simple lightshow.
