Installation whithout VirtualStore?!
LightJens1
FreeStyler Version: 4.1.0
Post by LightJens1 »
Hello everybody!
First off, I want to apologize for my poor English ...
My problem today is with the installation of the Freestyler (4.1.) under Windows 10. During the installation I select the directory "C:\Program Files (x86)\FreeStyler", where the installation then apparently takes place. In fact, a directory is created under "C:\Users\xxxx\AppData\VitualStore\Program Files (x86)\FreeStyler", which Freestyler then works with.
I find this very confusing, especially since I keep looking for my saved files.
Can I also work around this and force a "clean" installation without the VirtualStore?
Thanks for your support!
Crrispy
Bug Zapper...
Re: Installation whithout VirtualStore?!
Post by Crrispy »
Hello,
Launch the installation program as administrator. Then edit the properties of the desktop FS icon and under Compatibility, check "Run as administrator" checkbox.
LightJens1
Hello!
Many thanks to Crrispy! That was what I needed. Although there is a directory under VirtualStore again, but FS now saves my data in the program directory.
Many Thanks!!!
