More light rays
colombo
Has mastered Fixture Creator
FreeStyler Version: 4.1.2
More light rays
Post by colombo »
Good day. Is there a way to display two light beams in Magic 3D Easy View? In the Scanlibrary Editor, the Number of light beams option is set, if I set it to two or more, one light beam is still displayed. I found on the forums that it is not possible yet, but it was around 2010. Thanks for the response.
Android Dev (Moderator)
FreeStyler Version: BETA
Re: More light rays
Post by Mattotone »
Magic3D is a 3rd party tool that has been abandoned by the developer many years ago.
It still does the job reasonably well but lacks a lot of options that modern software such as capture or WYSIWYG have.
colombo
Re: More light rays
Post by colombo »
In my research, there must be at least one PAn or Tilt channel. Then the selected number of beams is displayed. If you have two or more pairs and two or more PAN or TILT channels, then unfortunately all rays move according to PAN1 or TILT1.
