Is there a fix for this error message? My system is running MS DirectX 12.
Whenever I try to open Magic3D viewer this msg pops up and won't allow me in.
Your graphic card is not compatible with Microsoft DirectX 9.0
- I Use FreeStyler for: Band
- FreeStyler Version: None
Re: Your graphic card is not compatible with Microsoft DirectX 9.0
You tried running as Administraor? OS?
- FreeStyler Version: 3.4.6
same problem here, also as admin
- FreeStyler Version: 4.14
HAve you tried compability mode?
