Suny DM-RGB400
nielsniels
FreeStyler Version: 3.6
Suny DM-RGB400
Post by nielsniels »
Hi all, I got two cheap mini lasers - Suny DM-RGB400.
Does somebody already made the fixture for my Chinese twins?
KrisRevi
Re: Suny DM-RGB400
Post by KrisRevi »
im looking for the exact same thing!
KrisRevi
Re: Suny DM-RGB400
Post by KrisRevi »
ok so blindly i made a fixture for the Suny DM-RGB400 :) mode,patter,color, pan and til (8bit and 16bit) :) if you want it just PM me and i'll send it :)
pbrady5
FreeStyler Version: 3.6.50
I Use FreeStyler for: Band
Re: Suny DM-RGB400
Post by pbrady5 »
KrisRevi wrote: September 17th, 2019, 1:30 pm ok so blindly i made a fixture for the Suny DM-RGB400 :) mode,patter,color, pan and til (8bit and 16bit) :) if you want it just PM me and i'll send it :)
Could I possibly get a copy? I'd really appreciate it! I tried sending you a PM about it, but its still in my Outbox so I'm not sure if you received it or not..
renaudcanuel
Re: Suny DM-RGB400
Post by renaudcanuel »
i need too ;-) i search everywhere for this fixture ;-)
Timleuken15
Re: Suny DM-RGB400
Post by Timleuken15 »
dit some one have the fixature?
Re: Suny DM-RGB400
Post by Jan_K »
Hej Laszlo
Please use the export function in fixture creator and upload the pff file.
fxt files don't contain all fixture information.
Laszlo
FreeStyler Version: 3.6.49
Twitter: -
Instagram: -
Re: Suny DM-RGB400
Post by Laszlo »
Hi Jan,
ok, done :)
sflsurfrider
FreeStyler Version: 3.6.51
Re: Suny DM-RGB400
Post by sflsurfrider »
hello. new here. i just got a sumger dm-rgb400 and i see its not in the list of fixtures. is the suny the same? any way that i could get a copy if it is? sflsurfrider@hotmail.com
thank you
quincydread
FreeStyler Version: 4.1.1
Re: Suny DM-RGB400
Post by quincydread »
So is there anyone that can port this .pff over to a Magic3D fixture file, i simply do not understand how to do it myself.. Resources on how to are extremely hard to find.
Im completely new to DMX and lasers, but i want to learn.. I really dont want to have to spend ~800+ just to get QuickShow, FB3QS, and an ILDA compatible laser
Re: Suny DM-RGB400
It tends to be much easier to make fixtures for 3d view using the scan library tool, open up fixture creator and add the same values to scan library editor
