Velleman Default Mode [SOLVED]
baggy99
Just started using FS
FreeStyler Version: 3.5.5
Post by baggy99 »
Hi
Dunno if this is an issue with the software, the hardware or my understanding of the software's functionality, but...
I would like the fixtures to retain the last command when the program is closed, ie if all fixtures we on red, I'd like them to stay that way when the program is closed down. Is this possible? If not, is it the Velleman hardware that's doesn't support the facility?
I appreciate that the system will presumably fall-over when the PC is switched off, cos the USB power to the Velleman interface is cut, but I don't see why that should be the case when the program is closed down. Any thoughts?
Thanks :D
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Velleman Default Mode
Post by Mattotone »
All lights will blackout when FS shuts down, im not sure wether FS instructs this or not.
The velleman interface cant continue to send dmx (even unchanging values) without Freestyler as its timings are all generated by the pc.
The enttec pro has an active buffer and will continue to sen if the program crashes.
baggy99
Post by baggy99 »
That's great - many thanks.
