Submasters -Can I add more and rename them...??
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
Hi Folks,
Just wondering if I can expand the submaster views by adding extra tabs and renaming them. I have tried all the usual routes with no joy. Thanks in advance for any help. Rgds Mac
Re: Submasters -Can I add more and rename them...??
There are only tabs with 5 Submaster on each tab.
so 4x5= 20 submasters, this is a Normal amount for a Lighting desk.
And no you cant rename the tabs.
/spitiy
StefanAtMess
Post by StefanAtMess »
Workaround for not being able to rename a submaster:
- close freestyler
- open the data.fsd file and look for the submaster name (something.fcf)
- edit the name (keep the .fcf !)
- in the Cues folder: rename the cue file to the same name you just used in the data.fsd file
