Recommend article on finding and fixing DMX problems
Have a Tip? Share IT!
imigyjunia
FreeStyler Version: 3.3.2
Post by imigyjunia »
Just came across an intelligient article on finding and fixing DMX problems. It is well written and specifies everything clearly. If you do not find solution your problem in the article you may find in the comments, :D
I just feel like recommending to everyone this helpful article. Hope you will like it.
DMX Fault – Finding and Fixing DMX Problems
In nights of no moon or stars, at least we still have brightness from LED down lights.
http://www.imigyled.com
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Recommend article on finding and fixing DMX problems
Post by matt »
Another thing you can do is test your XLR lines on a regular basis. I test all my XLR cables every 6 months. A Basic tester like this -> http://www.ebay.com/itm/Pyle-Pct10-8-Pl ... 3cbefd3450 is great!
Matt Hankosky
flickr.com/photos/mattxhank
Return to “Tips from the Pros!”
