I'd tried to install Freestyler on Ubuntu.
But i also get 'Error creating output Thread' 'ActiveX component can't create object'
It would be really cool to have freestyler run on linux
Freestyler under Linux zenwalk
- mistique
- FreeStyler Version: 2.95H
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Freestyler under Linux zenwalk
read through the rest of the thread, the answer was in here some where.
- mistique
I did this but still it doesn't work. When i run regsvr32 regtool.dll i get succesfully registered dll. But still the same errordavid007 wrote:Big news!!!
I managed to get Freestyler working under linux...
I've installed a registery tool in system32 that registers the neccesary ActiveX components.
Once run regsvr32 regtool.dll Freestyler works just fine...
Thanks to all who helped me to resolve this problem!!!
- djSupport
probably becuase u need to regsvr more files than just that... which ones i dont know i'd just do all the dll's and see what happens!
- FreeStyler Version: 2.96f
Hello People,
I'm also very interested in using FS in Linux (Ubuntu) + wine.
I guess the FS software is running if I read through this thread.
My only concern is the driver for my Enttec Open USB module.
If I can believe the Wine documentation, you can't install
drivers under Wine.
How does this work ? (If it does ?)
If I need the drivers for linux.
Which one to use ?
Regards,
Bruno
drivers under Wine.
Which one to use ?
Regards,
Bruno
- FreeStyler Version: 3.0.1
Installing FreeStyler in WINE
Installation on linux/wine.
It seems like there are a typical problem with some ActiveX "components" and the Windows registry
especially hirestimer.ocx
Numbers in the installation program gets shown with abnormal characters instead.
(I am not trying to generate DMX output, just to learn how to use FreeStyler for light programming)
from http://www.freestylersupport.com/fsforu ... p?f=6&t=34 it is suggested to run:
which I did after the first failed installation of Freestyler.
I get an error when trying to register hirestimer.ocx:
a Microsoft Foundation Classes Library, which is not distributed with WINE, must be present. I downloaded it from http://www.dll-files.com and put it in directory system32 and ran " (note command promt)
I don't know what part of the procedure I used, that actually did the trick. Perhaps it is enough to find, place and register MFC42.DLL in the windows/system32 directory before starting the installation.
Code: Select all
regsvr32 'C:\Windows\System32\msflxgrd.ocx'
regsvr32 'C:\Windows\System32\MSWINSCK.OCX'
regsvr32 'C:\Windows\System32\MSCOMM32.OCX'
regsvr32 'C:\Windows\System32\hirestimer.ocx'
regsvr32 'C:\Windows\System32\fsled.ocx'
regsvr32 'C:\Windows\System32\fsledr.ocx'
Code: Select all
Library MFC42.DLL (which is needed by L"C:\\windows\\system32\\hirestimer.ocx") not found
Code: Select all
~/.wine/drive_c/windows/system32$ regsvr32 mfc42.dll
Running FreeStyler in WINE
(This is not a regular bug report, as I don't think the sole developer has WINE support as a target, but you can guess at how well FS works under WINE)
Tested software:
FreeStyler 3.0.1
Wine 1.0.1 (on up-to-date Ubuntu 9.04)
FS can be started, but the main window cannot be resized.
If FS is not closed properly if the close/exit button in the window decoration is used (or other ways that the exit command comes from the window manager). If FS is closed by choosing file -> Exit, it works. The error is that when FS is started again, it only show a message saying that FS is already running, and exits again when the dialogue box is closed.
Some graphics are not showed correctly/the right place.
This is a poor performance of a app in wine, as if FS uses some system calls (or whatever it uses from the windows system), that other apps rarely use. Windows and WINE is not identical implementations of the Windows API's, and some parts differ more than others, and perhaps FS is using some that has a significant difference.
If Linux is a priority, try Q Light Controller instead: http://opendmx.net/index.php/QLC (and tell what features you miss in QLC)
Tested software:
FreeStyler 3.0.1
- wardomon
- Commited FS Forum helper
- FreeStyler Version: 3.4.6
I've tried QLC in Linux. It's easier to dual boot and run a Windows partition than figure out how to get QLC to do anything at all. Don't even get me started about the pitiful fixture list.
A little knowledge is a dangerous thing.
