BUILD LOG
OLD ANDROID FORUM
Locked
Android Dev (Moderator)
FreeStyler Version: BETA
BUILD LOG
Post by Mattotone »
Confirmed Feature Requests And Build LOG
Completed:
Improved menu structure,
Receive data back from Freestyler (cueNames, submasters details, override status etc)
VersionCheck, Warns user if version of FS used is lower than the current version required by the app and that some features will not work correctly.
Manual IP last used ip address will be displayed in the manual ip entry form (user request)
Rework all screens to fetch data from FS cue names/status, override names/status,sub master names/status,blackout/fav/freeze status,group names etc - Compleated
Submasters!!! Compleated NOT LAUNCHED YET
CueList Status Improved status of cuelists as per user request. - Completed
fixture, cue and override buttons names pulled directly from free styler rather than having to type them in.
Tablet Layouts better layout support for tablets and higher resolution devices - Completed
also will there be an addition to the fixture name (group name) page that indicates when they are active or not? a simple border around the button would be great- Completed
the selection button to maybe change another collour to indicate that it is active unless you can see the computer screen its impossible to know what fixtures you have selected and what ones you have not.- Compleated
Is there any way to integrate a button or different color button every time you hit a scene you know which one was hit? - Compleated
<<FADERS TO DMX OPTION>>- Compleated
<<Terminal>> - Compleated
Under construction
To Do Help welcome :D
Better menu icons.
Promo Videos.
improved promo graphics.
GoMonkey Intergration
user requests
individual fixture control, i know you have group selection which is fantastic but some times i need to move just one fixture in that group and i cant do that unless i setup every fixture as its own group.. its a work around but a pain in the ass.
Re: BUILD LOG
Post by Mattotone »
Whilst the screenshots bellow might not look much, its the first screens that have been able to get data from Freestyler.
Load a cuelist into freestyler and when you open cues on the remote the buttons are updated to match, no more manual text entry.
2nd: Screenshot of the version check screen, displays if the version of FS is not the latest version required for the app.
Re: BUILD LOG
Post by Mattotone »
New Update:
Common buttons at top and bottom of all screens, including a quick link.
QuickLink: Allows user to quickly toggle between last two visited screens EG Cues and overrides.
Fog controls fan and level controls on master screen.
Possible new cue screen.
New Masters Screen
New Overrides Screen.
Locked
Return to “Android.old”
