FS Remote for iPod/iPhone
macman21
FreeStyler Version: 3.4
Post by macman21 »
I am using freestyler to control a minspot rgbw, two intelligent scan 250's, two rgb par 64 cans, and a mini move led with an enttec dmx usb pro. This is a small setup I am using at my church for our VBS 2011 Beach Blast.
I have had trouble getting the ipod app (Freestyler Remote 1.2.0) to work. I tried disabling the firewall and running the remote server for the zinman app. I am running Freestyler 3.4 Beta. The ipod will not let me press the connect button after typing in my computer's local ip address.
I am not to awfully worried about getting this to work because I can already use remote desktop to set up and run cues from a remote location, but it would be nice to have the functionality.
Joseph Price - Audio-Visual Hobbyist - Freestyler 3.4 BCF2000 Saitek ST290Pro Flight Joystick Enttec DMX Pro
http://www.southerwinbaptist.org http://www.won4christmusic.com
http://www.won4christmusic.com/josephprice.cfm
dubmachine
FreeStyler Version: 3.3.2
Re: FS Remote for iPod/iPhone
Post by dubmachine »
your ip must be 10.x.x.x i believe, for me it only works like this, ive noticed i have my one router which i bring to gigs with me and its the only one that seems to always give me the right IPs. i use apple air port. also try not connecting dsl or anything unnessesary to the router. And my whole company runs the app all on jail broken phone with no problem. i did buy the app however cause it is pocket change well spent. but before buying i did download a cracked version that worked fine... also if your using a iphone 4 gsm from 2010-2011 it can have a faulty wifi. myself aswell alot of people have had to return cause of this.
ug999
I Use FreeStyler for: Church
Post by ug999 »
dubmachine wrote:your ip must be 10.x.x.x i believe, .......
the ip range is not relevant, any is working, fixed and dhcp.
Return to “iOS (iPhone & iPad)”
