Fixture File - 60W 4 LED RGBW+Amber+UV 6-IN-1 Washing Effect Moving Head Topic is solved
hcoff5250
FreeStyler Version: 3
Post by hcoff5250 »
After searching the forum and web, I cannot seem to find anything for this light below:
https://www.tomshine.com/p-l1614us.html
Would anyone have the Packed Fixture File for this light by chance? Even if it's not Tomshine?
Thank you!
:fs:
JDawg
Re: Fixture File - 60W 4 LED RGBW+Amber+UV 6-IN-1 Washing Effect Moving Head
Post by JDawg »
Haven't looked for this fixture but you can start with the owners manual and the wiki :)
FreeStyler Version: 4.1.6
Post by Rod_Horning »
I did not find a user manual. We may be able to assist you if you can post the DMX channel assignments.
hcoff5250
Post by hcoff5250 »
https://drive.google.com/file/d/0B-xwii ... h1dmc/view
Here is the scanned version of the manual that came with it. I believe the channel list you're looking for is on the last two pages.
Thank you very much for the quick response!!
Attached is my attempt for the 18 channel mode. Please test and provide feedback.
After you select the fixture click on the menu item Window -> All.
This will open the following helpful programming windows:
Colors
Gobos
Lamp
Pan/Tilt
The Colors window has 2 tabs: Fixed Colors and CMY-RGB
The CMY-RBG provides a color pallet which helps mix the RGB leds to your desired color. The colors controlled here are red, green, blue and white. Orange (first time I have ever seen orange) and UV are controlled by the standard sliders (upper right hand corner.
The Fixed Colors tab controls channel 16 - the predefined colors auto program and sound programs
The Gobos window controls channel 14 - the predefined motor movements and sound controlled movement.
When either the motor or the LEDs are controlled by sound the standard sliders are used to control sensitivity.
hcoff5250
Post by hcoff5250 »
Rod_Horning wrote: May 14th, 2019, 3:00 am Attached is my attempt for the 18 channel mode. Please test and provide feedback.
Colors
Gobos
Lamp
Pan/Tilt
Hey Rod_Horning,
The light will show color now, but the display color from Freestyler sill show a different color from the light. It will only show blue or red. The other thing I noticed is that the pan/tilt features make the light skip and gets caught up during movement. I can upload a video if it could help. Thank you so much for taking the time to make this, if there is anything else I can provide or do to get it working please let me know!
Please check the physical configuration of your instrument. The Freestyler fixture definition is for the 6 in 1, 18 channel mode. If your instrument is not physically configured to this mode it will not react to the Freestyler commands as you expect.
Yes, please upload a video.
hcoff5250
Post by hcoff5250 »
Rod_Horning,
Whoops! My bad I now have correct the channel on the light and it works GREAT! Thank you so much for your help!!! :D
You are welcome. Glad your light is working. Enjoy.
Stonewall45
Post by Stonewall45 »
Worked great for me! Thanks Rod_Horning!!!
