equinox onyx
souldude
Just started using FS
FreeStyler Version: 3.6.4
equinox onyx
Post by souldude »
Hi
had a search but can't find this light profile . has anybody got it or can someone put one together .
ive included the manual for it
says 10 or 14 channels . not much between them so 10 would be fine .
thanks
:fs:
FreeStyler Version: 4.1.6
Re: equinox onyx
Post by Rod_Horning »
Attached is my attempt for the 10ch mode.
The manual did not specify so I may have the RGBW channels incorrect. Please let me know.
The following helpful programming windows are available (top menu Window -> All)
Lamp
Macros
Colors
Custom Sliders
souldude
Re: equinox onyx
Post by souldude »
Hi
thankyou i will check this out
:fs:
souldude
Re: equinox onyx
Post by souldude »
Ok
colours are the reverse on the 2nd tower
Red opposite white
green / blue
blue / green
white / red
:fs:
Re: equinox onyx
That complicates things a bit.
In order to control the color properly in Freestyler you will need to use the 14 channel mode.
You will need to physically change the configuration of the instrument to 14 channels.
Attached is a fixture definition for the 14 channel mode.
I used the RGB segments feature so that you will have individual control of each lamp. In the Colors window note the check boxes in the lower left corner. The two on the right side, in the vertical column, tell Freestyler which bank to control. You may check either or both (or un-check both). This allows you to use the color pallet.
Again, I may not have the colors correct. Please check by using the standard Freestyler sliders:
Bring the dimmer channel (channel 4) up full
One at a time slide the 8 lamp controls all the way right - note the color - then all the way left. (CW is white). The lamp color will hopefully match the text of the slider. If not please note which slider controls which lamp and let me know - I'll fix the definition.
Re: equinox onyx
Internet issues. Hopefully file will attach.
souldude
Re: equinox onyx
Post by souldude »
ok many thanks will test out again and report back
:fs:
