54*3W Led Rgbw Par Light
Fillu
FreeStyler Version: x2
Post by Fillu »
Hi does anyone know if there is a fixture file already for this light or how to do it cause I can't manage.
https://www.aliexpress.com/item/8pcs-RG ... 16607.html
Attached is also the manual I got for it.
studijo
Re: 54*3W Led Rgbw Par Light
Post by studijo »
You have to use the fixture file creator if the file doesn't exist. This program is installed by default with FS. To learn the program it's a good idea to open an existing fixture, for example another rgbw led fixture and see how it is build up
Verstuurd vanaf mijn SM-G920F met Tapatalk
Freestyler 3.5.9 on Windows 8.1 with DMX4All USB interface.
BCF2000 with firmware 1.10
Fixture setup: 4 x PAR64 controlled by Dimmpack, 2 x Eurolite TSL-200 scanners, 1 x Ayra TDC-33, 1 x Geni FL-1800D strobo, 1 x Antari Z-1500 fog machine
Fillu
Post by Fillu »
Tried to but still got mixed up. Am not that much into building up things like these
firemoth
FreeStyler Version: free
I Use FreeStyler for: Church
Post by firemoth »
The fixture file I found had the colors backwards. Here is the one that I have been using
