MULTI SCAN ALLTECHPRO 4 X 10W RGBW Topic is solved
juninhorezini
FreeStyler Version: 3.6.2
I Use FreeStyler for: Band
Post by juninhorezini »
OI
PRECISO DE UMA FIXTURE DO MULTI SCAN ALLTECHPRO 4 X 10W RGBW...
SEGUE LINK DE VIDEO DO DISPOSITIVO:
https://youtu.be/VKPTXJUCih0
Nathanrs93
FreeStyler Version: None
Re: MULTI SCAN ALLTECHPRO 4 X 10W RGBW
Post by Nathanrs93 »
If you want a fixture creating, we'll need a manual or DMX chart to work from?
juninhorezini
olá Nathanrs93
eu não encontro o manual desse dispositivo elétrico na net... porem existe uma fixture do dispositivo ''showtec inversion 17ch'' que é muito parecido... mas a visualização no magic 3D easy view é comprometida, impossível elaborar algum trabalho...
segue o link para download do equipamento showtec inversion:
https://www.highlite.nl/silver.download ... _GB_V1.pdf
porem acredito que as funções não são todas iguais... apenas muito parecido.
Post by Jan_K »
Hej Juninhorezini
Det vil måske også hjælpe lidt hvis du brugte engelsk.
Der er fuld forståelse for at du eventuelt ikke skriver engelsk men så brug eventuelt google translate så har vi en mulighed for at forstå dig.
Jeg kan ikke se om jeg skal oversætte fra kroatisk eller russisk :D
juninhorezini
hi Jan_K, I had not thought of that, I'm posting again in English
'' I do not find the manual of this fixture '' MULTI SCAN ALLTECHPRO 4X1 10W RGBW '' on the net ... however there is a fixture of the device '' SHOWTEC inversion 17ch '' which is very similar ... but the display on the magic 3D easy view is compromised, impossible to draw up some work ...
follow the link to download the SHOWTEC inversion equipment:
https://www.highlite.nl/silver.download..._GB_V1.pdf
however believe that the functions are not equal to the electric device I need ... just very similar. ''
thank you
Post by Jan_K »
Hej again
I need to understand this correct.
Do you have a fixture for FreeStyler which is working
The fixture for 3D easy view don't work.
Just a small note. 3D easy view is a program from nicolaudie and they may have a fixture which works.
http://www.nicolaudie.com/
juninhorezini
Hi
yes that's right, because I contacted the nicolaudie and they asked me the SHOWTEC equipment manual,
but this equipment SHOWTEC is just like the equipment that I really need, which would be the MULTI SCAN X 10W RGBW 4 ALLTECHPRO
but not find the manual of this device
this is the inversion SHOWTEC:
https://youtu.be/HEmPjNq9mI4
and this is what I really need a fixture as described in the beginning of the post:
Post by Jan_K »
Without manual it is a bit difficult to help you.
I am not an expert in using 3D easy view but I think you may need to make a basic scanner with pan and tilt control and then use it x4 next to each other on the correct addresses.
That is the best advise I can give you at the moment.
juninhorezini
that's what I'm doing at the moment
but only in the 3D view,
did not live test equipment
I do not know if the channels to Go to work properly!
thanks for listening
Nathanrs93
If you can find the manual for this, then I'll see if I can help you with 3D fixture. I'm not the best, but I can get something working for you.
juninhorezini
ok!
juninhorezini
Hi
got this manual '' multi scan alltechpro '', it only shows the way to 9 ch. but it says it can be used with 12CH. if u can help me, I would get the fixture and the ssl file for viewing in 3D.
thank you...
