ist there a fixture for the Eurolite PAR65 RGB LED-Spot?
It has 5 Channels R-G-B-Stobe-Dimmer
Sorry but i have postet that before in the wrong section.
Greetings Kai-Uwe
Eurolite PAR 64 LED RGB
- DJ
- FreeStyler Version: 3.2.1
- djSupport
Re: Eurolite PAR 64 LED RGB
thats very easy to make have a go and just see if you can do it ( HINT: fil out manufacturer, fixture name, pick a picture then put 5 channel fixture then click enable RGB put 1,2,3 or what evers what then fill out strobe and intensity(dimmer) channel settings then save and your off!!)
- FreeStyler Version: 2.95f
Hello, I have the exact same issue as the original poster.
I have 4 Eurolite LED 64 RGB.
I don't know how to properly configure the fixture, so if anyone has the right file, I'd appreciate it.
I've tried several combinations of values in the fixture creator, but it just won't respond.
Help much appreciated.
- djSupport
put in the total channels 4 then click down bottom left corner enable cmy/rgb then click rgb values enter in the channel information
then in the intensity channel just put the 4th channel in that then fill out fixture details above save then it should work allakzam!!
Mmmm..
I have just tried this, severeal times, but still no light is comming out of my LED spots,
But they work just fine when they are on light-2-sound.
Any idea of where it goes wrong?
PC --> DMX = OK
DMX --> lamp cable = OK
Lamp, just been shipped to me by Thomann.de, and are working just fine..
Thanks a lot for the help people!
PC --> DMX = OK
Hey guys, just wanted to say that I got it all working now, and will be uploading the fixture to the new forum
- djSupport
can you explain what you did wrong? for the community and our knowledge? cheers...
- FreeStyler Version: HIPPY
Hello, i met the same problem: nothing works... Anybody could send me a print screen of the fixture creator page for the cells to fill please? i properly follow the instructions but nothing is working . Help me please
thanks a lot
thanks a lot
Hello again, that's good, i found the solution for this device
So, (for you and the knowledge) you make the good adress behind the spot and you select the "dip" 10 , i try for one spot in this moment and i'll try for 4 spot
I'll keep you in touch!!
thanks a lot
So Rich, enjoy
thanks a lot
So Rich, enjoy
- Just started using FS
- FreeStyler Version: 2.96j
So in conclusion, did anyone make a fixture file for the Eurolite LED 64 can??? Need one asap and I can't seem to get it to work using the fixture creator, thanks in advance.
