PEOPLE!! Please try to create the fixture on your own before asking for someone to make it! It could take WEEKS for some one to do it for you. The fixture creature is quite simple to use. just put the dmx channels in the boxes corresponding to the function. set your gobo and color channels, and your set. its not that hard. You have the program to make the fixtures, Its Fixture Creator.
Still Stuck? Open an existing fixture and look at how its made. Look at a few different fixture types, a scanner, a head/yoke, a laser, a color changer, etc. They are easy to make.
Also,
CHECK TO SEE IF SOMEONE MADE IT ALREADY! Check the fixtures that are pre-installed, and search the forum. there is a whole section devoted to use created fixture files on the home page!
Before you request a fixture to be made.
- Admin
- FreeStyler Version: NULL
Matt Hankosky
flickr.com/photos/mattxhank
