fixture cameo led bar rgba
DannyPulse
FreeStyler Version: 3.6.3
Post by DannyPulse »
i neea fixture for this led bar rgba..... searching ... I also tried for making one with fixture creator, but not responding..... its 4ch or 6ch or 19ch... ( 4ch for beginning I ok ) who can help me ??
Re: fixture cameo led bar rgba
Post by Jan_K »
Hej DannyPulse
As I read this then you have tried to make a fixture and the led bar don't respond to this fixture.
Please export this fixture to pff and upload it here.
And upload the manual. (Makes things a bit easier.)
Then I will have a look.
If it is the 4 channel fixture you have made, then my guess is that it is just RGBA channel control, and if that don't work then you have an other error in you setup somewhere.
