StageApe Barrier
rbfleming4
FreeStyler Version: 3621
StageApe Barrier
Post by rbfleming4 » February 26th, 2016, 11:42 pm
I am trying to setup the Stage up barrier and having issues getting the settings to work with Freestyler. Can someone assist. My church purchased 4 of these and we just changed from a smartfade controller to freestyler.
Thanks,
Link to StageApe fixture.
http://stageape.com/pages/barrier.html
DMX Mode:
Channel 1 0-40 dimmer mode
41-80 strobe mode
81-120 color change mode
121-160 gradual color change mode
161-200 section chase (8 sections of barrier chase)
201-255 sound active mode
Channel 2 0-255 all LED's dim/speed
Channel 3 with slider #1 set at 0-40 it controls the red LED's
when slider #1 is set at 41-80 channel 3 will now control these effects(channel #2 controls speed 0-255 slow-fast)
0-26 color 1 red strobe
27-55 color 2 orange strobe
56-83 color 3 yellow strobe
84-111 color 4 green strobe
112-139 color 5 aqua strobe
140-167 color 6 blue strobe
168-194 color 7 pink strobe
195-223 color 8 magenta strobe
224-252 color 9 white strobe
253-255 color scroll strobe BARRIER
Channel 4 with slider #1 set at 0-40 it controls the green LED's
with slider #1 set at 161-200 channel 4 will now control these effects(channel #2 controls speed 0-255 slow-fast)
0-20 color 1 blue section chase
21-41 color 2 aqua section chase
42-62 color 3 blue/green section chase
63-83 color 4 green section chase
84-104 color 5 yellow section chase
105-125 color 6 red section chase
126-146 color 7 purple section chase
147-167 color 8 pink section chase
168-188 color 9 white section chase
189-209 section chase 1 (each time the chase starts over it changes color)
210-230 section chase 2 (fills the bar with a different color in each section)
231-251 section chase 3 (makes the whole LED bar one solid color and then clears and starts again with a different color)
252-255 section chase 4 (chase down the bar filling it in with different colors) BARRIER
Channel 5 with slider #1 set at 0-40 it controls the blue LED's
with slider #1 set at 201-255 channel 4 will now control these effects
0-50 sound active strobe (white)
51-100 sound active multi color strobe
101-150 multi color section chase to sound
151-255 section chase 2 to sound.
