Stairville dj lase 150-rgy dmx Topic is solved
Could anyone help me with Stairville dj lase 150-rgy dmx fixtures?
Thanks...
Thanks...
- FreeStyler Version: 3.4.8
Re: Stairville dj lase 150-rgy dmx
Is it the mk2 version of the dj lase 150, or the older one? The new one have I belive 9 dmx channels, and 32 patterns, the old one hade over 80 patterns and 16 dmx channels.
I have fixtures for both, but since my old dj lase 150 rgy got stolen half a year ago and I know only use 8 of the new dj lase models, that fixture is the "best" I have one version of it for the 40 G lasers, one for 150 RGY Performance and 200 GVC Performance models. I´m not 100% sure that the 150 RGY Performance fixture works perfectly for "non-performance" 150 RGY model, but it should be really close.
I use the 40 G fixture and just added a color channel and changed some values to get the Performance fixtures, so it should be an easy fix:)
I´ll see if I can upload them later this week if you still need it, not by my Freestyler computer now..
//Robin
//Robin
It is older mk1 and it have 16channels, It would be nice, if you download it here , Thanks
Could you please send it to me too? I have DJ Lase 150 RGY 16 channel.
Thanks in advance.
Thanks in advance.
Could you kindly upload the file here?
Thanks very much.
Thanks very much.
Hi im also intressed in the 16 channel version
- FreeStyler Version: Beta
Hej.
Is it this one you are looking for then it is only 10 channel version.
http://images.thomann.de/pics/prod/255625_manual_en.pdf
Hej guys.
Here is a fixture that matcher the manual above.
10 Channels.
viewtopic.php?f=23&t=4464
10 Channels.
- I Use FreeStyler for: Film
Hello i'm interressing by your 40-g version because i don't manege to do my own fixture
(sorry for my bad language but i'm french)
- FreeStyler Version: 3.6.4
Thanks in advance.
Thanks in advance.
Older Stairville dj laser 150 RGY dmx
Helou Guys! I have that old version of Stairville dj lase 150 rgy dmx. And i need the fixture for it, if someone have it, and it's work. I have try to create one from zero, but without succes, i have try with version allready created from freestyler library and it doesn't work. It gives me some errors. If somebody have it, please write me, or send it to me. (The lasser works because when i put all the button adress to down side it lite up green/red lasser and apper that geometric shape) The interface works to, because i'm using it, with other moving head and it works perfectly. I have just this problem with that fixture lasser. So i ask you again, if someone have it, please send it to me.
- FreeStyler Version: 4.1.6
Is this the instrument for which you would like a fixture file?
Helou Rod! Yes that is!
Attached is a fixture file for your instrument. I hope it is usable for you.
After you select the instrument in the Freestyler work space click on Window -> All
This will display the following helpful programming windows:
Macros (the macros set the DMX value in channel 1)
Custom Sliders
Until you become familiar with using the fixture I suggest you keep the User Manual open to the DMX channel chart.
Custom Sliders
Hello Rod! Thank you for fixture! I will try with this fixture and i will write here a feedback! Thank you again for your time!
