Tape
Have a Tip? Share IT!
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Tape
Post by matt »
Use Gaffer Tape to Secure Power Cords down to the Floor. Do not use Duct Tape!
http://en.wikipedia.org/wiki/Gaffer_tape
Matt Hankosky
flickr.com/photos/mattxhank
dmxlighting
FreeStyler Version: beta
Re: Tape
Post by dmxlighting »
Some types of 'Cloth Tape' are also know as Gaffer, Gaffa, Duct, Duck, rig tape, ez-rip etc.
Depends who its made by or where you buy it as to what its called.
You cant just say 'Dont use Duct Tape'. Its an inacurrate statment.
Snowcat
Has mastered Fixture Creator
FreeStyler Version: 3.2.1
I Use FreeStyler for: Theater
Re: Tape
Post by Snowcat »
My rule of thumb is to NEVER use any tape that has the string grid backing on it (easy rip type stuff).
The glue is horrible and will gum up your cables very quickly. Far prefer to use rubber carpet strips when at all possible.
matt
Admin
Re: Tape
Post by matt »
It all depends on the Brand of Gaffer's Tape.
I always use ProGaff
http://www.rosebrand.com/product891/Pro ... -Tape.aspx
Always comes off nice and clean.
Matt Hankosky
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Tape
Post by Mattotone »
isnt duct tape (not duck tape) a generic tape used for reapiring heating ducts and usualy water resistant with strong glue and shiny. that stuff is a nightmare.
gaff tape is normally matt so not to reflect light and is widely used in the industry due to being designed to tear and come away cleanly unlike duct which is designed to not comeaway.
Theirs a lot of post here about removal of residue. http://srforums.prosoundweb.com/index.p ... 69/0/16/0/
Dropbox. 2GB account is free! http://db.tt/J4c5G8C
Get $100 in cloud credits from @DigitalOcean using my link: https://m.do.co/t/1dfa4b120c4c
Re: Tape
a nother tip is that you must twist the end of what you have Gaffert, Gaffa't, Duct, this why it will be easier to remove.
matt
Admin
Re: Tape
Post by matt »
or tab it!
Matt Hankosky
Return to “Tips from the Pros!”
