JB Systems - Spacelaser (update ! other version was wrong!)
LJ Robin
FreeStyler Version: Last
Post by LJ Robin »
this fixture contains JB Systems - Spacelaser
It has 5 channels:
1 On/Off (sort of lines,like picture)
2 Gobo's (figures)
3 "X,Y" Movement (I work on a fixture to get it in the "bezier controller" like the space color laser)It doesn't work because it doesn't support X and Y movement !!!
4 Rotate
5 Zoom
This is another version beacause the other upload was wrong. Sorry! ;)
I hope you'll have something about this post.
Questions , remarks? ask,tell me
Sorry for bad English but I'm from Belguim :D
:fs:
Tested: Yes,works
Version 1.0
tohe006
FreeStyler Version: 2.95f
Re: JB Systems - Spacelaser (update ! other version was wrong!)
Post by tohe006 »
Could someone explain too me how to install / choose this .pff file in the main freestyler software add / remove fixture section..
I have tried to place the "packaged fixture file" in the fixture directory but it will not become visible when I try to select an fixture.
I have also tried to open the pff file in the fixture creator and then tried to save it as an *.fxt but then I get "subscript out of range"
Just want to have a working fixture "profile" for my "space 1" laser thru my welleman DMX controller
Have tried to search the forum for "space 1" topics ...
Thanks in advance... / Tony
Windows/Phone App Dev (Admin)
FreeStyler Version: 3.6.49
try double clickng it in its directory it should then add it!
tohe006
Post by tohe006 »
Thanks for your help... Oups...Misstake by me.
I did not check all the "subdirectories/folder-contents" in the left menu hard enough.
The Space 1 was located in JBSYSTEMS and not in the default ( after installation of Freestyler ) JB SYSTEM
Regards / Tony
Return to “JB Systems”
