Lights Mirroring? - Issue with sequences
Katniss2Everdeen
FreeStyler Version: 4.0.1
Post by Katniss2Everdeen »
Hi, I'm new to FreeStyler, so if this is simple I apologize. So I have 4 wash lights of the same make model and brand. I created a custom fixture for them and it works great. I record a sequence for a single light, play it back and the one light that I choose works as expected. However when I open up the Cuelist and run the sequence there, and run a sequence for the first light, the fourth light copies the first, and same for the second and the third. I've triple checked that the lights are NOT in the sequence. When I edit the sequence and run through the steps only the initial light that was selected is changing. I've looked around and couple seem to find a solution or anyone else having this issue. I apologize if I'm blind and it's right in front of me. Any help that can be provided would be amazing. Thank you all so much! Go FreeStyler!
FreeStyler Version: 4.01
Re: Lights Mirroring? - Issue with sequences
Post by Partyman »
Please make sure that all lights have their own address. Can you post a freestyler backup file so that we can take a look?
Katniss2Everdeen
The link for it is here: http://atheria.org/backup.fbf
I did use auto addressing, and can control the lights individually just fine, when editing the sequence I only record for one light and it responds properly. But as soon as I run the sequence in the Cuelist the issue occurs.
