4.0.1 BUG!! Only 20 Cue buttons functional in ver. 4.0.1
- Just started using FS
- FreeStyler Version: 4.1.0
Hi, next bug discovered in v. 4.0.1.
If I create cuelists and put them to cuelist buttons, buttons 1 to 20 behaves normal, all others (21-96) gives me "Subscript out of range" message. There is no problem with the lists, because the same cuelist assigned to button 1-20 is running OK, but if I put him to any button in range 21-96, "Subscript message" jumps out.
Thanks for recovery.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: 4.0.1 BUG!! Only 20 Cuelists possible in ver. 4.0.1
Please report via the bug tracker, https://www.freestylersupport.com/bugs
- FreeStyler Version: 4.01
how are you launching the sequences(mouse, touchscreen, midi, phone,...)?
A little about Bug tracker:
Sure, I know, bugs shoud be reported in Bug tracker, but unfortunately I´m not able to log in that tracker. Three times i tried to sign in, each time i set other mail and name combination, and tracker always fucked me up after activation ("bad name or password" message, although both were 100% fine. After clicking on "Forgotten password" and and fill in the e-mail "APPLICATION ERROR #1905" always jumps out ). Sorry, but I´ve loose my patience little bit I don´t know what´s wrong, but the Bug tracker obviously doesn't like me.
That´s why I posted all bugs here, sorry for that. If someone with a functional Bug tracker approach could put this bug in the Bug tracker instead of me, I would be grateful.
Back to the problem:
It´s not about launching the sequences, it´s about launching cuelists by the cuelist buttons no. 21 to 96. And all options are returning "Subscript out of range" - even if I launch them by MIDI, touchcreen or mouse. It doesn't apply to cuelist buttons 1 to 20, they are launching assigned cuelists perfectly right, it´s the problem of cuelist buttons 21 to 96 (provided that cuelist buttons 1-20 are occupied).
I´m using FS for 5 yrs and previous versions did not have any of the problems I am reporting here - therefore, I rightly believe that these are bugs in the latest, otherwise very successful version. After installing version 4.0.1 I deleted all my recorded lights, sequencies and cues and did everything from scratch again, to avoid conflicts between older and newer versions of files (BTW it was about 100 hrs of work ). But this Cuelist bug and Override button bug: viewtopic.php?f=6&t=8827 still bothers me.
Please change your sequence window view to buttons (and have 32 button setup selected) drag a cuelist into any or all of the buttons in slots 21-32 and let me know if those cuelists in slots 21-32 are working correctly.
Re: 4.0.1 BUG!! Only 20 Cue buttons functional in ver. 4.0.1
Nope, still the same problem
I've recorded short video, launching Cuelists 19 and 20 works fine, than I put cuelist called "Fire" to button 21 (it's the same cuelist as on button 19), lauch 19...OK, launch 20...OK, launch 21 and.... "Subscript out of range"...
Video is here: https://youtu.be/o_P31M1riUw
Situation is the same in all layouts.
- djSupport
on a separate note please try the lost password function again and let me know if it's now working?
No, still "aplication error":
APPLICATION ERROR # 1905
Maximum internal processes achieved. Contact your system administrator.
Please use your browser's "Back" button to return to the previous page. You can correct the errors indicated by this error message, or choose another action. You can also choose another option from the menu and go directly to another section.
Previous non-fatal errors occurred. Page contents follow.
Translation of the Czech text in picture:APPLICATION ERROR # 1905
- djSupport
Private message me your email address and I'll look into it...
- FreeStyler Developer
- FreeStyler Version: 3.2.1
This issue has been confirmed and is fixed in the next release.
Raphaël
- djSupport
Top stuff
Great job, I'll impatiently look forward that release Thanks a lot
