Shape => delay problems with save in shape window
d.sosnowski
FreeStyler Version: 4.0
Post by d.sosnowski »
freestyler version4.0
I click create sequence. I choose four moving heads. Head. I click the Pan / Tilt window. Moving heads generate a circle, for example. In the shape window, I set a delay. Moving heads lag behind each other as it should be. I Saves the sequences and unfortunately the delay does not record. Why?
Thank you all for your help.
draceq
Just started using FS
FreeStyler Version: 4.1.0
Re: Shape => delay problems with save in shape window
Post by draceq »
Same problem, delay is not saved in last version (4.0.0). In previous versions this worked fine.
PLEASE CHESK THIS ISSUE, it's really annoying and it completely degrades the possibility of use this new, otherwise very good improved version.
Thanks.
draceq
Post by draceq »
This bug (and few others) was repaired in the last version (4.0.1). Now all delay functions work properly.
Good job, guys, thank you. The latest version is really fancy ;) :fs:
