Good day,
It is possible to set somewhere that the sent values of the dmx channel are 0 or 255. Any other value of the channel is forbidden. I know how to set the interval of sent values of dmx channel, but I did not find writing only two values. Is it possible at all? Thanks for the response.
DMX channel value only 0 or 255 Topic is solved
- colombo
- FreeStyler Version: 4.1.2
- FreeStyler Version: 4.01
Re: DMX channel value only 0 or 255
When you create an override button you can save any value you want
- colombo
My point is, if I accidentally enter the value 125, for example, so that 255 is actually sent over the DMX channel. If set to 0, DMX 0 is sent. If set to 1 ~ 255, DMX 255 is sent.
I do not believe there is a function that will limit output to only this or that
- colombo
I thought so. You can limit the interval.
