FastCue never stops
andrea300
I Use FreeStyler for: Theater
FastCue never stops
Post by andrea300 »
Hi guys,
I need help!
i created 20 sequences putted into my cue list.
I play the 1st and then I need that at the end of the last 20th sequence the cue automatically stops.
This never happens.
How can i fix this? :fs:
Nathanrs93
FreeStyler Version: None
Re: FastCue never stops
Post by Nathanrs93 »
If you go into the settings, there should be an option to keep the cuelists running? Is that what you mean?
andrea300
Post by andrea300 »
No,
"keep the cuelists running" is useful but it is not my trouble.
For exxample: my Cuelist_1 is made of 10 sequences. When i push Cuelist_1 button, i need that, at the end of 10th sequences, the cuelist automatically stops.
Instead, the cuelist rewinds and restarts from the first sequence <--- I don't want this
Thhanks for the help!!
andrea300
Post by andrea300 »
any helps?
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
I don't think freestyler supports this natively, you can try my addon Go-Monkey that will allow you to build a list of sequences that play one after another only once.
If not show us a screenshot or even better a video of what you are currently doing.
andrea300
Post by andrea300 »
I created my Cue stack buuut now:
how to stop the last sequence automatically? there's no commandss :x :x
Post by Mattotone »
If your using go monkey, for the last sequence in the stack de-select the loop option in the editor to make the sequence play once.
