Open the program - strange value of dimmer Topic is solved
Gorat
Just started using FS
FreeStyler Version: 3.6.51
Post by Gorat »
Every time when I open the program, the values of the dimmer on the first device are always the same (not equal to 0). They must be equal to 0
Why is this happening?
Screenshots: https://dropmefiles.com/8FLad
FreeStyler Version: 4.01
Re: Open the program - strange value of dimmer
Post by Partyman »
There is a setting in the top menu that allows you to save startup values to whatever you want, also there is a setting in fixture creator to set the default settings for each fixture.
Gorat
Post by Gorat »
Partyman wrote: July 31st, 2020, 8:08 pm There is a setting in the top menu that allows you to save startup values to whatever you want.
Thank you. It works :)
