Hello! I am from Ukraine and this topic is so hard for me.
Help me please.
For example, one company has a backup of freestyler with all its instruments and sequences, etc., And this company also has a 3D Easy Magic View, this scene is associated with FreeStyler. I need to create new sequences and programs for lighting using Easy View, but what files will the company have to send to me so that I can manipulate the fixtures, and at the same time my actions from fixtures will be displayed in Easy View?
Pleas, I really need speed help with this question.
BIG THANKS!!!
3D Sunlight Easy Magic View + FreeStyler
- FreeStyler Version: 3.6.50
- FreeStyler Version: 4.01
Re: 3D Sunlight Easy Magic View + FreeStyler
You will need to make sure all of the fixtures you are using in Freestyler are available in the 3D View (if not you will have to create a fixture or edit an existing fixture). You will then need to load those fixtures to the same addresses in the 3D View. In the "Universe patch" of 3D View select Freestyler. You should now be able to use it.
The 3D view view is a fantastic way of being able to do offline programming but it needs a lot of setup to work properly and give you true representations
Thank you, the company should send me a saved file from 3D Easy View with a scene related to Freestyler, as well as a backup with devices from Freestyler, right?Partyman wrote: ↑October 8th, 2019, 6:48 am You will need to make sure all of the fixtures you are using in Freestyler are available in the 3D View (if not you will have to create a fixture or edit an existing fixture). You will then need to load those fixtures to the same addresses in the 3D View. In the "Universe patch" of 3D View select Freestyler. You should now be able to use it.
I hope so for you
