Hi all,
Is there a way to map like the master intensity to a slider? on a midi controller. I want to be able to control the speed of chases/sequences and overall brightness with something like that.
Please help!
Using APC Mini for Sliders
- Just started using FS
- FreeStyler Version: 3.5.5
- Twitter: twitter.com/djsolstice
- FreeStyler Version: 4.01
Re: Using APC Mini for Sliders
Yes, I use APC minis for this all the time. You will just need to assign everything under midi setup
I also use the APC Mini and it even works with the LED lighting feedback on the buttons.
