A couple of times i had some issues (faulty fixture which lost it powersupply) with the electrical supply to my fixtures, which caused a lost of data in the freestyler DMX-chain.
No problem with that, but it also caused the bad behaviour of rebooting my laptop.
What possibilities are there to prevent freestyler or the dmx interface from rebooting the laptop.
Crashing laptop
- FreeStyler Version: 3.6.4
Re: Crashing laptop
hmm a fresh install of windows? thats not normal.. maybe your Dmx hardware drivers need updating?
Re: Crashing laptop
I mean,.. If i pull a cable and kill the chain, nowt happens. There shouldnt be any "feedback" so thats odd. Id say the driver for the hardware is spagged... what hardware you using?>
Re: Crashing laptop
with rebooting i mean, the laptop restarts (not installing windows)
Re: Crashing laptop
Windows 10 updated, 16 ram memory, I-7.
"Enttec dmx usb pro" into a powered usb-hub
Re: Crashing laptop
Yes, you're right...pulling out power and dmx cables is not the cause.
Tried this a lot yesterday with a working dmx-chain.
Wundering what could be the cause of this malfunction.
- FreeStyler Version: 3.3.6
Re: Crashing laptop
Sounds strange but I guess that somehow your USB Port draws too much power. If you mention a failed power supply of a fixture there might have been a larger leaking current over your DMX cable into your interface and into your laptop. The most power supplies of laptops and PCs are resetting (either only the USB supply or the whole system) if they detect a short or overcurrent.
The Enttec interface is supposed to have a galvanic isolation to prevent things like this to happen. Maybe it failed.
It still could be a software problem with outdated or incompatible drivers.
- FreeStyler Version: 3.6.49
Re: Crashing laptop
Does the laptop reboot with a BSOD ?
If yes, take a photo of the message code near the bottom of the screen. That message code could help you pinpoint the cause of the reboot.
