udmx freestyler 3.4.6 not communicating in magic 3 easy view Topic is solved
dadutz81
FreeStyler Version: 3.4.6
Post by dadutz81 »
i just buy it last week and i install but with the cd installer dont have magic 3d easy view so i download it on .but when i try to create my own style and view on magic 3d it wont work i hope you can help me on my concern thank you..im using windows 7 .did i need to update the software or not?
FreeStyler Version: 4.01
Re: udmx freestyler 3.4.6 not communicating in magic 3 easy view
Post by Partyman »
You must install the 3d visualizer while installing freestyler (it's an option in the Freestyler install). If you install it separately it will not work
dadutz81
Post by dadutz81 »
i remove the 3.4.6 freestyler software and i installed 3.6.49 and it works now normally.thanks for the help sir partyman.i install the 3d visualizer while installing freestyler.thank you very much.
Bikash Saha
Twitter: no
Instagram: no
freestyler software 3.6.51
Post by Bikash Saha »
anyone have freestyler software 3.6.51 pleasesend
