Help Please - FreeStyler start, opens AutoCAD configuration
Goatrancer
Post by Goatrancer »
Hello,
I have the following problem and urgently hope for help:
After I set up my operating system (Win7 64bit) and have now installed Freestyler, I get when opening, 4x consecutively a message from AutCAD_2015 "Please wait while Windows AutoCAD Architecture 2015 - German configured. From AutoCAD comes then the error message '.NET 4.5 is not installed', but probably nothing to do with the actual problem has (I think). I have to quit these two windows 4 times before FreeStyler then configures and starts.
However, then comes the error message that FreeStyler does not find the file 'USBDMXSI.dll'. However, the file is in the instalation folder.....!
I have already installed FreeStyler several times without any problems, but now I am going crazy ....., all night I tried to solve the problem alone.... :? :? :? :(
Please help me, I have no idea what else I can do :roll:
I am German and apologize for my bad grammar :oops: :roll:
Thanks, Andre
FreeStyler Version: 4.01
Re: Help Please - FreeStyler start, opens AutoCAD configuration
Post by Partyman »
Freestyler requires dot net framework 3.5 to operate. I would start by installing that then move forward
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Agreed.
After .NET installed restart. Also if Freestyler still doesn't work after, the just reinstall Freestyler.
Tronnyi
Post by Tronnyi »
I've got pretty much the same issues, reinstalled Freestyler multiple times, had net framework 4.7 installed already and AutoCad is not installed anymore (uninstalling was a bit tricky, even cleared the registry with ccleaner though)
Has someone already found a solution to this? I think the issue might be caused by an AutoCad feature called Freestyle.
