About fixture channel
Motsik
Post by Motsik »
Hello, i have a china led spot 60w without manual.
I find a fixture but is not full compatible.
Intensity channel is in strobe, now how can i control the intensity ?
FreeStyler Version: 4.01
Re: About fixture channel
Post by Partyman »
You will need to open the file in "fixture creator" and change the parameters that are not correct and save as a new fixture. You will then export the fixture to a file and double click file to install on your system
