Enntec pro
dekw1
FreeStyler Version: 3.5
I Use FreeStyler for: None of your damn business!
Enntec pro
Post by dekw1 »
Is anyone having issues with the latest version of freestyler and the enntec pro dongle
Un gel spГ©cial est utilisГ© pour aider si vous avez vasculaire cГ©rГ©bral et de crise cardiaque.
FreeStyler Version: 4.01
Re: Enntec pro
Post by Partyman »
I use many of them. What type of issues are you having and what OS are you using?
dekw1
Re: Enntec pro
Post by dekw1 »
Im using windows 7 and my dmx pro goes into fault (green led on constant)
The dmx pro program cannot reset the fault...... I can only reset it with my xp computer
It is currently with Enntec who say they cant find a fault ......
Re: Enntec pro
Post by Partyman »
Hmmm, have not had such issues with any of my systems. I would make sure in windows "device manager" that the usb ports are NOT allowed to disconnect to save power.
dekw1
Re: Enntec pro
Post by dekw1 »
FreeStyler Version: N/A
Re: Enntec pro
Post by remco_k »
dekw1 wrote: August 27th, 2018, 4:28 pm Im using windows 7 and my dmx pro goes into fault (green led on constant)
Does it work at any point, or doesn't work at all while connected to Win 7?
In latter case, you might just have a (FTDI) driver issue.
There is a test tool: http://www.enttec.com/products/controls ... o-manager/
dekw1
Re: Enntec pro
Post by dekw1 »
it works for a while on windows 7 then the green led comes on constant and stops sending dmx.
