INSTALLATION PROBLEM
elsavo
FreeStyler Version: 3.6.4
I Use FreeStyler for: Theater
Post by elsavo »
hi guys, i have a problem with freestyler. when i try to open the program istantly start to run windows installer.
and not freestyler.
i tryed to unistall freestyler and reinstall it a lot of times but the problem is always the same.
someone could help me?
thank you
Lwcevents
Just started using FS
FreeStyler Version: 3.4.6
Re: INSTALLATION PROBLEM
Post by Lwcevents »
Hi Ya
Uninstall, Reboot - run disk cleanup, run CC Cleaner (or similar) to remove any registry values - reboot.
See if that helps.
