Couldn't open midi out
AndreZeisberg
Just started using FS
FreeStyler Version: 3.6.3
Post by AndreZeisberg »
Hi folks, I have a problem when I start program I get this error message.
Couldn't open midi out, rc = 2
How can i Fix the error? Please help me :)
Sorry for bad ;)
FreeStyler Version: 4.01
Re: Couldn't open midi out
Post by Partyman »
It means that in the midi settings you have a device selected in the second slot that is not connected to the PC
AndreZeisberg
Hi
The Universe1 is uDMX an the Universe2 is No Interface
I do not understand the mistake :-(
Post by Partyman »
not the same area, midi settings are in different tab of setup menu
AndreZeisberg
Ok I check after work :-)
I thank you :-)
AndreZeisberg
Here is my attitude to standard still the error :?:
AndreZeisberg
What can I do? to solve the problem ?
Regards Andre
Post by Partyman »
Not sure, mine say "No device". I would try a fresh install over the top and see if it fixes. Maybe try the rescan and see if a "No Device" appears as an option
AndreZeisberg
With Rescan appears no input and no output but can not save it already 7 times new instaliert it is strange :-)
AndreZeisberg
I could fix this problem the wrong audio driver was the problem :-)
Post by Partyman »
Glad you got it sorted
