dmxsoft option not working bug tracker not working
masterfeedback
FreeStyler Version: 3.6.4
Post by masterfeedback »
Hi I am trying to use the dmxsoft interface and I get cant find lsharddevkit.dll !
a google comes up with nothing
It locks me out of the program as the next time I open the program I get the "could not open midi out rc=2" error (no idea why i get that but got that before when I was using a udmx plug in adapter) it appears over the cant find lsharddevkit.dll warning but i cant close the rc=2 slash nothing works their is no way of killing the" couldnt open midi out rc=2" error warning that is over the cant find lsharddevkit.dll warning
I have to control alt del task manager kill freesyler to get rid of the " couldnt open midi out rc=2" error then I can click the ok on the cant find lsharddevkit.dll at that point the program closes
I have the sushi-ds dongle
wires
Re: dmxsoft option not working bug tracker not working
Post by wires »
Like you I get the message "can't find LsHardDevKit.dll" when trying to use my Sushi-DS (DMXsoft i/f)
The file LsHardDevKit.dll is present in the c:\freestyler\ folder along with the main freestyler executable. I don't know why it cannot find it :-{
More to follow if I find a solution. Will try copying it to windows or system32 folders tomorrow
FreeStyler Version: 4.1.6
Post by Rod_Horning »
From the info on the web it looks like there is software to download. Is the dll part of the down loaded software?
wires: try copying to sysWOW64
masterfeedback
well I copied the file to the sysWOW64 folder and it has got rid of the error but the sushi-ds is still not recognised I was told by Dmxsoft that it should be the dmxsoft option but click save shut down then restart and its back to no interface found :C (and when you click save the fixture dose'nt go into black out
FreeStyler Version: 4.01
Post by Partyman »
You should be able to hit enter to clear the first error, once inside the program go into midi settings and select "No output" for device 2 input and output. That will get rid of the midi error.
masterfeedback
Clearly their is a breach of contract between the lead developer of freestyler and dmxsoft/daslight as this software dose not work with the dongle and the developer/ developers don't seem to care shame as this will kill freestyler in a court case .... ;'(
kaczor_ks
Post by kaczor_ks »
For the SUSHI-DS interface to work with FreeStyler, a C ++ redistributable package is needed. I do not know exactly which version, that's why I installed a few and it started working.
